How hot do my exhaust pipes get?
I'm hooking up a wideband A/F guage to my TA, and the instructions state that an optional thing you can do is put a heat sink in between the O2 sensor and the exhaust bung. I decided to do this for extra insurance to keep my sensor as cool as practical.
Well, I soldered some extra copper that I had on the heat sink. The solder melts @ 460 F. Is this solder that I used going to melt from the heat of the exhaust pipe it's hooked up to?
Here's a picture of what i'm talking about in case you're confused.
Not a huge deal, but i'm curious if I should use some hotter melting solder. Thanks for any advice.
Matt
Matt
Location: Live Oak, FL - in the woods where the creatures lurk.
The idea being to let the probe end do its' job but keep the upper portion as cool as possible? If the manufacturer recommends then sounds good to me. I think you'll be more than safe with the solder you used. That far downstream is not superhot, unless for some reason you are on one of the header primary tubes.
Gerald
Gerald
Thanks for the quick reply Gerald.
I'm planning on having the bung welded onto the X-pipe if there aren't any clearance issues. That way it gets exhaust gasses from both banks.
Matt
Matt
Matt
Matt
