**HELP**Car missfiring on all cylinders except 5 & 7
I've noticed the car missing at idle and getting worse. I replaced the current NGK 55's with new ones & Taylor thunder volt wires. Missing is worse now. My first test drive the car drove amazing. I went back home and finished bolting the drivers side coil packs down and went out again. This time it ran like crap and the SES light started flashing Went back home moved the wires around on the drivers coil pack harness. Still missing at idle but fine under load...
I took it to a local shop today and they hooked a scanner up. Missfire gets alot worse at idle but still ok under load? Changed wires back to stock with no difference. Any suggestions are appreciated.
Kevin
__________________
Kevin
__________________
Kevin
__________________
Kevin
__________________
Location: Live Oak, FL - in the woods where the creatures lurk.
OK, they hooked a scanner up. Did they drive it with the scanner hooked up and check everything out? It's been my experience that many shops don't try to drive/log real time data, just use those little plugin modules to try and diagnose what they don't know jack about. (/rant off/)
Also not uncommon to get misfires at idle after LT install.
Kevin
