What dimensions XR1 to get rid of rasp/drone?
I had no problems before the slightly bigger headers, LSX, and bigger cam but now I have a rasp/interior-drone problem. I have a 3" Kooks Y-pipe.
It's gonna be going in the I-pipe.
Which of the following must I use? Don't wanna have fitment issues, and obviously I'd like to go with the biggest inlet/outlet muffler possible so as not to hinder flow too much.
http://store.summitracing.com/defaul...h.asp&x=12&y=7
40944, 40943, 40086, 40640, or other suggestion XR1?
I don't know which one everyone uses since I haven't seen part numbers posted and only one inlet/outlet measurement posted (3 in 3 out). I'd like to use that one
Thanks!
Christopher
Thanks!
Christopher
Originally Posted by ddelallata
the 40085 is the one that most people including myself use. be prepared to bang the floorboard a bit.
I won't have drive-shaft clearance issues with this muffler will I?
I have a Lingenfelter 3 1/2" drive-shaft Needed it for safety issues when I do my 60 - 200 video
https://ls1tech.com/forums/attachmen...chmentid=37980
MASS seller approved
You guys want the 40085: http://www.eadperformance.com/catalo...roducts_id=311
You should be able to install it towards the back of the I-Pipe with out any issues.
Search for borlamouth for a soundclip of this muffler.
Have you dyno'd your SS on a dyno other than a mustang? What was the A/F?
I'll bet that cam sounds like music to one's ears
