whats the smoke from
ok i just got hooker exhaust put on today and got my cats gutted and had the sensor welded back in.so its been 3 days now and i still notice that if you cruisin around at high rpm and then just stomp it down run it up to a high rpm and let it starts to smoke you can see it ..its blue white looking smoke and smeels of gas is it fluding my opinion .and would 02 simulators fix this
whats the smoke
ok after my new exhaust setup my car likes to smoke after revving it i had my cat gutted and sensors welded back in.the smoke smells of gas ..would o2 simulators fix this
If its after you let off a hard accel and its a good bit of blue smoke, it may be your rings. I am having a similar problem @ 110k miles. How many miles on your motor. Also, you need to remember that exhaust pipes come with some sort of oil coating on them that burns off for about 3-4 days and smokes. Wait a bit and see if it stops.
The gas smell is normal with gutted cats, and some blue smoke (oil consumption) is normal after high rpm runs, its called blow by. If its an extreme amount then there might be a problem.
a friend of mine has SLP headers with a Borla exhaust, whenever we mess around and I am behind him, his car blows out dark bluish smoke, and yes it is only at high RPM's and he has about 80K on his car.....
