Porting a F.A.S.T 90mm lsx is it worth it??
Just wondering if it is worth me porting a LSX 90mm intake that's going on a 408 w/AFR225's and 11.5-1 with a 253/257 643-646 cam or should i just leave it alone Also a NW90mm tb as well
It matters whose doing it and if you have money layin' around or are truly looking to make some good power for the money spent. I say it's not worth it 90mm TB and intake will support a shi* load of horsepower.
LS1 Tech Administrator
Originally Posted by GREATWALLTA
Why would you want to do something like that? With the FAST 90/90 you will run out of mods before you run out of air TRUST ME.
Porting a FAST intake is a necessary mod when running good cylinder heads. Even with small runner heads like AFR 205, the FAST 90mm cannot keep up with the airflow of the heads. Porting is a must. The correct porting is worth an additional 7-10 rwhp on a 346 and even more on a larger motor. My motor is proof. I gained 27 rwhp with a Ported FAST 90 with a 90mm NW TB over an LS6 intake and ported TB...and get this...I was running stock exhaust manifolds, stock cats and a 215 cam. Porting a FAST 90 is money well spent if you have someone porting who knows where to port it. Port it the wrong way and you have a very expensive boat anchor.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
That is an uneducated statement.
Many people "port match" the intake and heads to ensure maximum flow. If you don't know what you are doing, spend the money and have it done right. When it is done right, the results are good.
Andy
The fast looks to come with extra material so you port match it to the heads you have, I don't think you want to be messing much further up then 3-4" unless you really know what your doing. It's quite obvious why you would want to port it once you have it apart. This is much more then a 'bolt' on to get your moneys worth from it.
I totally agree, I had mine done recently along with some hand blending of my heads. Lingenfelter Performance Engineering did mine for obvious reasons...I cant wait to get it on the dyno and see what gains were achieved. Before numbers are in my signature. After numbers are pending..but will be posted.
Originally Posted by ninobrn99
so are there any benefits to getting a ls6 intake ported?
Originally Posted by LSUxBlake
I've heard of a few people doing it, although I've never seen any conclusive results on how it turned out. You may see minimal gains with it, I don't know if they'd be gains big enough to justify the cost of getting it done, although it's definitely less costly than the 90mm FAST.
What did it cost you to have Futral do your porting?
