should i go another step colder on plugs?
i am running the tr-6 now but they are still pretty white. i only had about 50 miles on them when i checked so i dont know if that was enough to have signs or not. the electrode is whitish/gray but mostly whitish. the porcelin is white still. should i go the next range colder on the plug? or check it now? i have about 150 miles on them now.
I also had tip-in knock since getting the car new, and ran tr6's for awhile which helped but not completely. They would also stay pretty white like yours. But I completely fixed the problem with the combo of: Rapidfire #8 plugs (@ .05), 28# injectors (with correct PCM changes), !EGR with PCM changes (no added EGR timing). Can't say which change helped most, or if any was not needed. Supposedly I don't need the injectors, but the stock 26# would go 100% duty cycle at around 5K rpm. Using stock timing except for no EGR advance.
this is some good info, the porcelain doesnt tell all.plug reading sounds like you figured it out though
