header question??? velocity merge like kooks
I am interested in the velocity merge that kook uses... does it help out low and mid range trq and power???
will that type of collector work with a 224/224 tight lsa cam??
READ the STICKY
3rd one down about induction/exhaust it will tell you what you want to know About 2/3rds the way down there are some very good articles.
where both headers 1 3/4" or where the QTP's stepped???
Also, I am going with 2.5" X-pipe over the axle (79 Z28 LS1 swap), but I want all my trq down low, what mufflers should I use? will a straight thru type hurt my low end trq???
