did u need all of this for a oil pump swap??
ok im installing my new LS6 oil pump here soon and do i need all of this stuff??
Crank Pulley Bolt (Part #12557840)
- 6 quarts of oil, new filter
- Jug of dexcool compatible coolant (unless you save your old stuff)
- Timing cover front seal (Part #12561244)
In addition, 1998 Cars need (unless you've already switched to the new style metal gaskets):
- water pump gaskets (Part #12559271)
Yup sounds like the list, except you'll also need a new crank seal.
But other than that ... sounds like your good to go. Unless of course you want to throw a cam in there while you've got it all apart
