if you have ram air from factory will you gain any hp with slp lid?
any help is appreciated, so if i get an slp lid and do the fra mod that you do with the lid will i gain anything over the factory ram air?
Every little bit helps, but by just cutting out the plastic in the 'free ram air' mod, I'm not sure if you're actually doing any good. The kit that SLP sells includes an air duct, and seals that go around the pieces you cut. Without the duct and especially the foam seals, whatever air you free up is only going to basically splash around the engine comp. before it hits the filter. There was also a real Ram Air mod available a few years ago, I think they stopped making it. It was call the 'Brian Green Ram Air mod'. It told you how to cut off the factory blocking channels in your ram air hood, and gave new seals and channels to flow the air. Just cutting out the plastic plates won't do any good if you don't give the air a direction to flow effeciently.
I installed SLP w/ smooth bellows and performed free air mod. if you arer talking about slp lid only then you can perform mod, if you are talking about slp kit then mod would be different, more for the kit. lid only mod,well my filter gets dirty quick. I think the free ram air mod works in the sense that the inlet hole is bigger so its not sucking air to hard , try sucking from a straw, now make a hole about an inch from end and you can feel the extra free flow, sucking more air in faster. kinda the same. remove baffle in front of radiator and baffle in hood nostril. some take out hood screen too . I left mine in . hope this helps.
fuerzaws6
fuerzaws6
