air bleed tube location...
Old 10-30-2005, 11:46 PM
BackinBlack02SS's Avatar
Default air bleed tube location...
This may sound like a dumb question, but does your coolant air bleed hose, aka tb bypass hose, hose run over or under the ac hose?
Old 11-04-2005, 05:45 PM
WILWAXU's Avatar
Don't think it really matters as long as it safe from hitting the belts.
Old 11-05-2005, 07:33 PM
Yes, I know, but I simply want to know for the stock factor.
Old 11-06-2005, 04:47 PM
I took a look today at my friend's stock 98 Z28 and his is on top, and upon moving the hose around it really can only go above the hose or else you will have rubbing issues. Also, for those with an SLP or similar smooth bellows, make sure you pay close attention to the bypass hose and water pump pulley so that it does not rub.
Quick Reply: air bleed tube location...
