View Poll Results: Are duals worth it?
Yes
50
83.33%
No
7
11.67%
Indifferent
3
5.00%
Voters: 60. You may not vote on this poll
duals
True duals are insane. I put down 341/354 with mods in the sig. Great flowing exhaust helps a lot. And me personally I love the look of duals on a camaro. A t/a is a little different because you kind of EXPRECT the tips where the areas for tips are. But anyways DUALS own any exhaust IMO.
Well worth it. I love mine. If you angle the tips out to the sides instead of straight down it will help with the drone, and I put some dyno mat, actually it was phat mat in my car and it helped even more. I could never go back to a y-pipe setup again.
They are so definetly worth it. When i first bought my car i had stock headers, y, and slp loud mouth. Then switch to SLP LT's, 3" Xpipe, & Magnaflow 4x9's. Just recently switched the Magnaflows to Sweet Thunder mufflers. And let me tell you that True duals are the best exhaust systems out there. Tons of people have complemented me on how good it sounds.
-Joel
-Joel
http://community.webshots.com/photo/...28017291xXOEtw
Besides when you have the exhaust dumped it looks absolutely mean (this was before i took off the magnaflows for the sweet thunder)
-Joel
-Joel
True duals are great. Mine are lanes TD's dumped before the axel and there isn't much drone at all unless you are in 5th or 6th gear(M6). I think they are cheaper than a Y-pipe and catback anyways.
I just extended my TD's out the back because the interior noise finally got to me. It still sounds really good, but so much better inside the car. Dump them for now and extend them out the back when you have the money. I will post pics next week when I have the tips welded on.
well worth it imo there are pics and an idle clip here of mine https://ls1tech.com/forums/showthrea...0&page=2&pp=20
I dont THINK so unless you have the extra money to spend,and its not like you get to enjoy looking at them.You guys are using all 2 1/2 right?I got some serious 3 1/2 pipe right from the headers all the way back to 7 1/2 oval tips.No cats either;I got so much air flowing i had to put a resonator on it to keep it from burping.
Nobody needs backpressure. Any backpressure is bad. What you might need is exhaust gas velocity.
Duals sound MUCH better than a Y-pipe. I LOVE my duals with large cam. The idle and large throttle opening sound freaking AWSOME.
There is a measurable horsepower gain as well, especially under the curve.
good point thanks for keeping me on track still i was just trying to get across not many people need 3.5in exhaust. but yeah teh sound of the td's is awsome
