Dr. Gas or Burns Stainless Oval pipe?
Old 11-07-2005, 07:28 PM
MyriadPhoenix's Avatar
Default Dr. Gas or Burns Stainless Oval pipe?
I was wondering if any one has done a true dual dump before the axel setup using oval pipe? If so other than the x-pipe what pieces will I need? ie..how many 45 and/or 90 degree's I will need? and how many straight pieces I will need. I plan on also using the oval spin tech mufflers.
Thanks for any input.
Travis
Old 11-07-2005, 08:15 PM
red6speedss's Avatar
do anyone make an oval or flat muffler?
Old 11-07-2005, 08:18 PM
Default muffler
yes, Dr.Das does.
Old 11-07-2005, 08:45 PM
Ping King's Avatar
make your own...thats what i did...just squished it slowly in a press sandwhiched between 2x4...then for bends..i cut a bunch of slices with a chop saw and made a gradual bend by welding them together.
as far as a muffler...you could cut and weld an oval inlet on.
