help me pick plugs/ gap
LS1Tech Administrator
Received 1,467 Likes
Originally Posted by ls2 bait
what is recomended? car will have lt's, ory, catcback/ cutout, lid/ cai, ported maf/ tb, ls6 intake, pulleys. should i go colder? close the gap? all help is appreciated.
What effect does running a colder plug have on the chambers? A colder plug will cause less detonation on a higher compression chamber....because it runs colder? What setup do you have that entails you to be running a colder plug? Wouldn't a colder plug be in everyones best interest because a colder plug means less heat in the chamber, and that means the A/F mixture will only ignite with the spark? Isn't this ideal?
Thanks
Thanks
