slp ls6 egr block off...
I tried a freeze plug in mine and it didnt work out.The intake is real thin where they drill it.I barely snugged it up tight and the plastic started to crack.I couldnt get it to seal.I believe I used an 1-1/8".Might of been 1".
I ended up just using that liquid steel epoxy,like what's used for tb's,to seal up the hole.Its been like that for over a year with no problems.If you do use a freeze plug,be real careful when tightening it.
Well shoot, know you gotta be frustrated. If the 1" is too small and the 1-1/8" is too big you have to be close. Have you tried filing/grinding the plug down a little?
SSU's Drunk Typing Whore
Yeah I know...this sucks.
I mean there has to be something that you can just screw on to it as well. Instead of hammering it.
Maybe a cap that is used for plumbing or something? I found this cast iron cap that would work, but it would look like **** in the process...maybe I will go back and see if I can find some copper caps at lowes.
Just to be sure we're on the same page - what you bought looks like the plug in this link right? http://www.ls1.camaro.net/sections.p...ricle&artid=70 Shouldn't have to hammer it in.
This is the one I was lookin for but they said a copper one would work as well...
https://ls1tech.com/forums/showthrea...ht=freeze+plug
I guess I should go back and ask for a rubber one?
Sorry about the link - fat fingers, should be http://www.ls1camaro.net/sections.ph...ticle&artid=70 scroll down to the bottom.
will that one still work for the SLP one though? cause the threads on the egr port are on the outside...so the hose from the egr system gets screwed onto the manifold part...
Did you take the Slp pipe off of the intake?Or are you trying to plug the actuall pipe?If you're plugging the pipe,you would think you could just put a threaded cap on it.Even though like you said it wouldn't look the greatest.
On mine,I took the pipe off of the intake.I couldnt get the rubber freeze plug to seal,so I just epoxied it shut.
You can see in this pic where I epoxied it.
Oh alright you took the whole bloody thing off then
Yeah I am trying to get somethin on that threaded pipe. Would that rubber expansion plug work at all? is that the one that you tried?
I am also not looking to ruin it in a way...I would like to still have the option of using the EGR later on...or if I sell this for the FAST setup I would like it still work and all...
I'm not sure of the inner diamater of the pipe,but a rubber freeze plug should work perfect on it.If not,a threaded cap w/thread sealant should work as well.Only thing is I'm sure of the size.
Alright, I finallt found somethin that fits...
Used to work at a plumbing company as well...so that helps.
3/4" Brass plug - looks pretty good as well on the car cause its brass and all.
Glad you got it takken care of.
Yeah I was thinkin about that as well...
**** man I am too; pain in the *** but I can finally get rid of EGR and AIR
Hey thanks for the help as well...along with everyone else
UH, my SLP LS6 with EGR had a brass bulkhead fitting that was installed in the egr hole of the intake. It used a nut with ferrules to attach/seal the egr tube to the fitting.
The fitting is nothing more than a compression style tube fitting similar to a Swagelok, Hylock, Parker, Yor-Lok, etc. All I did was left the fitting in the intake but used what is called a 'Plug' in tube fitting terms in place of the nut that came with the fitting. Note that these are NOT the same type of compression fittings that you would pick up in a hardware store for use on copper line (for eg. when plumbing dishwaser supply or ice maker supply) The ferrules inside the fittings are entirely different between the two.
The fitting is a 3/4" Tube OD so the Swagelok P/N is B-1210-P (where the 'B' denotes brass)
Go here: Swagelok Tube Fitting Plug to view the part. Type in the P/N from above and hit 'Go' it will take you right to the part I mention.
Or if you want you can got here: McMaster Carr Search on Brass Tube Fittings - got to bottom of page 123 and you will see the Yor-Lok Brass Compression Tube Fitting Plug #5272K136 $4.57/ea.
Sorry - neither one of these sites would allow me to link directly to the page of their catalog in question...
This is the cleanest and best method of sealing off that port. You don't have to modify the intake in any way and using this method is completely reversible - you can unscrew the plug and use the nut with your egr tube any time.
Ok, I must be retarded or something, I am a soon to be retired squid. I did the EGR Mod to my 2000 TA not too long ago and had problems with Vacuum leaks. I ended up buying that expensive "O" ring from a GM dealer and used a bunch of Teflon tape to amke a pretty good seal. Fast forward to now, I got the car back from the dealer, after I needed somework done to it, new windshield wiper moter and module. I noticed that it was idling higher than normal but would go back down to around 700. I took my trusty HP programer and Teflon tape out to the driveway and I thought I had fixed everything. Now the car is idling weird again. I am thinking about getting rid of the EGR but am confused, the whole sailor thing again. What size plug would you use for both the intake and the exhaust manifolds? How would I attach it to the Intake manifold, I didn't see anything to screw it into. Thanks in advance.
