What cat recommended?
Proabably going to change passenger side cat convertor out on 01' ws6. What is a good one that is recommened?
Is it bad to put in one aftermarket cat and leave other one stock?
Is there a write up on how to change cat out?
Thanks
Doug
Thanks
Doug
P0430 code? Could also be a bad rear 02/leak on that side. Just to be sure you're aware, stock cats are covered for 8 yrs/80K under the federal emissions warranty.
LS1Tech Administrator
Received 1,489 Likes
The only aftermarket cat that I've ever liked was Random Tech.
Like said above, first see if you can get it covered under warranty.
The dealer said they check it with a computer, and so far say its not a clogged cat as they can see. Another shop swicthed the O2 sensors around to check them. I just want to stop my car from jerking. Any write ups on how to take off and install, and do i really need to do both sides if one cat is bad?
Thanks
Thanks
