Opinions on prothane poly motor mounts?
Old 11-15-2005, 10:01 PM
seminolecjZ28's Avatar
Default Opinions on prothane poly motor mounts?
I am just wondering how the poly motor mounts from prothane are. Such as vibrations or anything else. These would be for a 98 z28.
Old 11-15-2005, 10:26 PM
ttp....
Old 11-15-2005, 10:46 PM
TAQuickness's Avatar
one of the best mods you can do
Old 11-15-2005, 11:24 PM
JRracing's Avatar
I want to know more about this also!
Old 11-15-2005, 11:31 PM
SSU's Drunk Typing Whore
Lithium's Avatar
TAQuickness is right...it really helps out a lot. Search the forum...plenty of threads out there with good info.
Old 11-16-2005, 12:02 AM
Full-Force's Avatar
they are a must IMO. If you have a 6 speed especially.
Old 11-16-2005, 02:44 AM
mrbobo's Avatar
Thumbs up
Great mod.
Old 11-16-2005, 02:58 AM
BrianC98Z28's Avatar
Are yall doing both sides or just drivers side?
Old 11-16-2005, 03:20 AM
xthephilx's Avatar
Why would you do only one side?
Old 11-16-2005, 07:34 AM
ive seen several people only do the drivers side to prevent it from movin over to stop the y pipe from hitting.
Old 11-16-2005, 08:31 AM
JRracing's Avatar
I would think you would do both. Think about it. If you do the drivers side to keep it from raising up. Why would you not do the passenger side to keep it from rocking down?
Doing one side sounds stupid. It would make one side stiffer than the other.
Old 11-16-2005, 08:44 AM
dug
dug's Avatar
I cant wait to do mine. Motor shakes way too much.
Old 11-16-2005, 09:50 AM
777's Avatar
The engine will torque to the driver side. Plus the for the driver side you only have to remove the alternator. The passenger side you have to remove the a/c and possibly the starter. Pass. side is more of a PITA. I haven't done either yet, just gathered from information I've read. If you have y-pipe banging the driver side poly mount will most likely clear it up because the engine won't torque to that side. It's kind of a band-aid. If it were me I would do both sides, I don't like halfway doing something, even if it takes more work.
Old 11-16-2005, 10:01 AM
Pimpium57's Avatar
How do the Spohn mounts compare?
Old 11-16-2005, 10:22 AM
JoeyAnderson's Avatar
What about for the cammed guys? My motor shakes like mad, and I'd like to stop it, but I don't want the entire car to shake like that, either.
Opinions?
Old 11-16-2005, 02:58 PM
Moderator
jimmyblue's Avatar
Poly mounts will let the motor shake less but
only because more of the shake is transferred
to the car body. The heavier body will move
less than the motor alone, but you will feel it
where you wouldn't on bungy mounts.
I have them on both sides. I initially noticed a
little more idle shake inside the cabin but soon
got used to it. My motor is all stock though, so
only the occasional idle miss for engine shake.
Old 11-16-2005, 03:12 PM
smontana16's Avatar
i have them on both sides and it made the car seem smooter at idle
Old 11-16-2005, 03:52 PM
DOUBT IT's Avatar
Go ahead and do both. If your car has any miles on it and you've driven it hard, there's a good chance your motor mounts are worn out.
Both of mine were.
Anywho, two words... DO IT!
Old 11-16-2005, 05:57 PM
SUX2BU's Avatar
i have solid motor mounts and i could BARELY feel the car shake when i had a big cam in it.
Old 11-16-2005, 06:23 PM
bitchncamaro's Avatar
Well i just did the driver side and no more bang n the floorpan ..... stock is junk .... great mod after fighting my y pipe for three weeks
