"WTF is this thing?" Part 3...
Old 11-16-2005, 12:30 AM
xthephilx's Avatar
Default "WTF is this thing?" Part 3...
Got my wiring harness back today. I have a couple of questions about a few plugs on the harness:
#1:
Where does that go?
#2:
What goes in this slot?
#3:
What is this and what do I do with it?
#4:
Where does this go?
#5:
x2
#6:
Not sure if this is an LS1 piece. It may plug into my mazda chassis, but I haven't moved its body harness over yet
#7:
These two harness plugs are on a large separate thing of wire. I believe they connect to the transmission.
#8:
What connects to that?
#9:
Where do these two plugs go?
#10:
This appears to be a ground strap. It comes out of the harness close to the alternator. Do I just connect it to the block?
#11:
Is this correct? The piece marked "ground" is another thing that looks like a ground strap, like #10.
#12:
Another possible ground strap. Just connect this somewhere on the block as well?
Old 11-16-2005, 12:34 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
1 looks like egr on the passenger side.
the other picture with 2 in it looks like the lid and the TB sensors.
Old 11-16-2005, 12:42 AM
xthephilx's Avatar
mm...can you refer to the numbers of the pictures? I posted a bunch
Old 11-16-2005, 12:43 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1 and 9
Old 11-16-2005, 12:46 AM
xthephilx's Avatar
Would #1 plug into the hole for #8 then? or do I not know what the egr thing looks like?
Old 11-16-2005, 12:55 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
no it would go into the portion that sits on the passenger side header. it plugs from underneath it. but you dont have one it looks like.
Old 11-16-2005, 01:16 AM
xthephilx's Avatar
Don't 2002 LS1s not have EGR?
(It's a 2002, btw)
Old 11-16-2005, 01:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
haha, oh ok. Well then I really dont know what 1 is. but that is what 9 is given its location
Old 11-16-2005, 01:22 AM
Starz T/A 17's Avatar
#6 looks like an OBD2 port to read codes
Old 11-16-2005, 01:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that was wehat i thought then he made the mazda comment
Old 11-16-2005, 01:26 AM
xthephilx's Avatar
3 wire plug: MAF
2 wire plug: IAT
(from torquecentral)
xthephilx's Avatar
And yeah, #6 is the OBD2 port. It looked kind of like a mazda body harness plug
Old 11-16-2005, 01:35 AM
xthephilx's Avatar
Can I get confirmation about 7 being tranny plugs?
Old 11-16-2005, 01:45 AM
AllThrottle4U's Avatar
#2 map sensor, you will need a plug for this
#3 a/c?
#4 reverse lights on m6
#5 a/c?
#7 tranny m6 reverse lockout solenoid and speed sensor
#8 evap canister?
#11 ground to chassis
#12 ground to block
Old 11-16-2005, 01:47 AM
xthephilx's Avatar
#5 is (according to torquecentral) something that connects to the ignition cylinder.
Not sure if it connects to the ignition on or the starter circuit though.
xthephilx's Avatar
#3 may be AC, however.
Can't find the plug for the MAP sensor. Could it be #1?
Old 11-16-2005, 01:52 AM
TAQuickness's Avatar
#2 MAP sensor
#3 looks like a knock sensor
#4 looks like oil pressure sending unit
#6 OBDII port
#9 MAF & IAT
#10 connects to the alternator
#11 will suffice
#12 connecs to the back of the heads
Old 11-16-2005, 01:56 AM
xthephilx's Avatar
Could #3 connect into that hole right above the "ground" text in 11?
Old 11-16-2005, 10:24 AM
FILAMENTWS6's Avatar
#3 is the AC refrigerant pressure sensor.
Old 11-16-2005, 10:34 AM
The hole above the "ground" text in #11 is a block plug for the coolant passage (i think).
#3 screws into the ac line that runs between your evaporator and condenser.
