synthetic oil
Old 11-19-2005, 04:38 PM
gordonloser's Avatar
Default synthetic oil
My car has about 65,000 miles on it and I have always used regular oil when changing at every 3,000 miles. I usually use up to 1-1.5 qts. Can you change to synthetic oil after running the car this long on regular oil? Will it help or hurt anything or just drain my wallet?
Old 11-19-2005, 04:57 PM
black01_WS6's Avatar
you can change to synthetic, but you may use a little more oil then usuall because it is a thinner oil.
Old 11-19-2005, 05:24 PM
natronathon's Avatar
i reccomend a thicker synthetic. Usually when you switch to a synthetic, your oil consumption should drop, since the synthetic oils have a higher flash point that dyno oils. I reccomend Mobil 1 0w-40. I love it, protects great at ALL temps, and is a good think oil, yet flows as well any!
Old 11-19-2005, 06:05 PM
john shea's Avatar
I googled synthetic oil and this proffesor said to explain
it to the layman if you take a quart of regular oil in the winter
and pour it. It will pour like mollasses while the synthetic will
pour like it's a summer day.It's all in the viscosity.
Old 11-19-2005, 07:41 PM
BlackHawk T/A's Avatar
Which makes a good Synthetic 100x better on really cold mornings...molasses would take a while to get through your engine on startup huh?
Old 11-19-2005, 10:20 PM
JEB Garner's Avatar
I suggest using AMS OIL. I believe that it is the best synthetic oil out there. It is a bit expensive but worth every penny.
Old 11-20-2005, 12:46 AM
destroyerSS's Avatar
you'll be fine switching now. But like others are saying go to a slightly higher viscosity The Mobil 0-40 is Ok and easy to find. Lots have spoken about the German made Castrol but it's harder to find
Old 11-20-2005, 01:18 AM
its better than ok, its a very good oil, It has a hths rating of 3.8 which is the same as the amsoil and german castrol.
Old 11-20-2005, 01:34 AM
It was a figure or speech. Relax your mobil stock did'nt drop
Old 11-20-2005, 02:50 PM
BriancWS6's Avatar
Go ahead and go to the synthetic if your wanting to. If your looking for a good oil that is readily available then go with the Mobil 1 5w40 truck/suv formula. Patman said it is the preferred viscosity out of the Mobils, where the 0w40 european formula "used" to be...I am going with the 5w40 on my next change.
Old 11-20-2005, 03:02 PM
SIC LSX's Avatar
What oil do i need to run? I have a 85,000 mile ls1.... lol my old Dodge Ram i got 300,000 miles out of it running regular 20-40
Old 11-21-2005, 01:27 AM
jetman101's Avatar
Default 1/2 and 1/2
A rule of thumb is to go 1/2 and 1/2 for 2 oil changes due to the diffrence in thickness
Old 11-26-2005, 04:08 PM
BriancWS6's Avatar
I have NEVER heard of such a thing.
Old 11-26-2005, 08:32 PM
ok...so I be slow now, so be nice to me. I went to the autozone.com site to look and see if they have the german castrol syntec and they don't even have a listing for 0w30 oil. They have an HD30 but it is not synthetic from what I can tell. Is the HD30 the same as 0w30?
Old 11-26-2005, 08:40 PM
GuitsBoy's Avatar
No, i dont believe it is. If they dont have GC, then look for M1 0w40 or order some amsoil
Old 11-26-2005, 08:45 PM
Shirt_Ripper's Avatar
hd30 is not the same as 0w30. 0w30 is a muti viscosity oil while hd30 is "straight 30" aka 30 weight all the time.
Old 11-26-2005, 08:51 PM
thanks for being gentle guitsboy...but shirt ripper....i do like llamas
Old 11-26-2005, 09:07 PM
GreekGator's Avatar
Mobil 1 5W40. Great oil!
Old 11-26-2005, 09:08 PM
GreekGator's Avatar
Mobil 1 5W40. Great oil! The only place i know that carries it is Wal-mart. They also carry the 0W40 if you want to run that.
Old 11-26-2005, 09:25 PM
TA TECH's Avatar
Or ya can try a synthetic blend!
