BorlaMouth Owners Please Comment!!
I have LoudMouth II with longtubes and ORY. I have asked input on a sollution to my loudass car. Several have suggested putting a Borla XR-1 in the place of the SLP resonator. I would like for BorlaMouth owners(or people who have heard BorlaMouth) to comment on the sound of that setup. I don't want to waste my $ unless it will make a noticable difference. I don't mind my car being loud, I don't even mind the highway drone, but I hate the popping raspy sound around 2000. Any help would be appreciated. Thanks
i had the lm with lt's and ory, and now i have the borlamouth and it makes a very noticeable difference in decreasing rasp and it is still nice and loud. cause i too like it loud and i didn't want to lose the loudness. i say go for it
I'll be honest I've never listened too one in person, but I've downloaded nearly all of LS1Sounds.com
On the vids I certainly prefer the sound of the LM over the Borlamouth. But hay I'm sure it'll sound different in person as the camcorder mics are pretty poor quality and the compression of the vids is variable.
Oh BTW, there are loads of different Borla XR-1 mufflers, I'm not sure which one people use, but there are at least 3 or 4 different types that 'could' be used. An that doesn't include the sizes of each either.
Location: Live Oak, FL - in the woods where the creatures lurk.
I like mine. I don't think it's super loud,
and I'm running headers and no cats.
Mine stays up in the rpms a lot around town,
too, because of the 2.73s & 3500 stall.
The XR1 to put in place of the resonator is
40085. It's the 5" round.
There is an oval 3" in/out but I don't know if
it will fit. It may if turned on it's side.
I have an oval XR-1 on my LM. The sound is great - as in exactly what I was looking for, and I have no clearance issues. Albeit, it would have been a lot easier to install the round muffler instead of the oval.
I've got a couple questions. I have the loudmouth and i would like to add a muffler just to get a deep tone and good performance Over the resignator. Would there be a difference in sound & performance if i got the 12'' compared to the 15''? I would not like to put the muffler where the resignator would go i would like to put it behind the axle in the tail pipe assembly (kinda like the borla cat back) would this be a problem? Thanks for the help!
I like mine there is still rassing between 2000-2200rpms but only happens when I try to save gas and shift from 3rd to 5th or 6th mostly getting on the highway. As far as Loudness can be racecar loud when you rev it, But not too loud when the revs are down. We have picky cops where I live and I've gotten by them with no problems. After installing my 3.73 gears there is a bit more drone on 6th gear in the highway cruising at 80mph, but with the stock 3.42 it wasn't noticible. Bellow is a link to another post. I put 2 sound clips up there.
https://ls1tech.com/forums/generation-iii-external-engine/369021-how-reduce-my-exhaust-sounds.html
Originally Posted by Killer_Bluebird
You could do it but you will have 2 things to deal with You'll need to cut into the pipe to the Right side tip and you'll need to figure out a way to be able to block the other pipe other wise most eshaust will just go out the open pipe and it will be a wast of $100+ muffler. You may just want to put a cutout before the muffler (althought space is tight) or 2 cutouts on the y-pipe. That way you can go from nice loud to "I heard you comming from about 3 miles away"
Anyway i didn't think about that.. How much room/Clearance is there when putting the muffler under the car? does anyone have a pic? also i am adding a e-cutout before the muffler that i have sitting around here from my true dual set-up just incase i don't like the sound.
Or, what I would like to do, fit 2 XR1s in the back.
If 2 were placed side-by-side in the back it would be
easy to have them both exit on the left rear. Or with
a little fab work they could exit both sides (my preference).
This would retain the Y split with no blocking.
Originally Posted by gwj
You could use two short mufflers in the back.
SmokedOutZ28-
Not talking about putting them by the DS-
Talking about the stock muffler location.
Put one XR1 on the pipe crossing over to the left.
Fit a piece on the "Y" to turn the same direction
and put another XR1 alongside.
Then either exit both on the left or fab a pipe to
turn back to the right side of car.
Or there may be a way to fit an oval XR1 on each
pipe before it exits the rear.......this would require
2.5" in/out instead of the 3".
SmokedOutZ28-
