dumps or run the pipes out back
i have pacesetter Lt and will be running TD with one chamber race mufflers. I was wondering if i should run dumps or run the pipes out back. Let me
thanks shaun
thanks shaun
If you run them out the back, your interior noise level and vibrations will go down, but keep in mind that routing true duals over the axle on an F-body is usually pretty pricey. So I guess you need to decide if the extra cash is worth it to you. Personally, i'd recommend going over the axle, it looks better that way, and the decreased noise level would be worth it to me IMO.
