View Poll Results: Which Manifold??
LS6
95
85.59%
BBK
16
14.41%
Voters: 111. You may not vote on this poll
BBK vs. LS6 (Intake Manifold)
Old 11-29-2005, 08:19 PM
slayer6x6's Avatar
Default BBK vs. LS6 (Intake Manifold)
Im trying to decide which would be better for my car. I searched through some threads but I would still like some recommendations. So vote Damnit!!
Right now my main engine mods are a lid, Pacesetter L/Ts, and the LS1 Hotcam kit. I was about to buy the LS6 but I came across the BBK while looking around.
After searching, it sounds like Im going to need a new throttle body with the BBK? So if anyone has any suggestions post em up!!!
slayer6x6 is offline
Old 11-29-2005, 08:23 PM
Full-Force's Avatar
I dont enough about either to vote but I can tell you that all you will hear on here is about the heat soak. Im sure the composite runs cooler but how much cooler? And is it that big a difference to make a big difference in pwer? I dont think so but I will enjoy watching this thread.
Full-Force is offline
Old 11-29-2005, 08:41 PM
Drew778's Avatar
I would think the BBK would flow better and you can always ice it down?
Drew778 is offline
Old 11-29-2005, 10:11 PM
slayer6x6's Avatar
As far as heat soak, and icing the manifold goes. I will not be at the track very often, maybe just once or twice to see what it can do. 99% of the driving will be done on the street. So I guess heat soak really isnt an issue for me.
Old 11-29-2005, 10:13 PM
slayer6x6's Avatar
BTW, I love the way that the BBK looks
Old 11-30-2005, 08:43 PM
TNMuscle's Avatar
LS6 by far
TNMuscle is offline
Old 11-30-2005, 09:30 PM
CRL 01 SS's Avatar
Get an LS6 intake and get your stock throttle body ported.
CRL 01 SS is offline
Old 11-30-2005, 09:41 PM
Jeffs99SS's Avatar
Heat soak isn't just something you run into at the track. A hot intake on the street will give you the same drop in power. On the street, though, you don't get the chance to ice it down.
Jeffs99SS is offline
Old 12-01-2005, 12:43 AM
NemeSS's Avatar
ls6 has been proven time and time again,just look at the FAST lsx manifold,made of composite for a reason, makes more power than a aluma version. cause of the heat soak composite can also be iced down
NemeSS is offline
Old 12-01-2005, 12:53 AM
Full-Force's Avatar
How much power i being lost from these aluminum intakes because they are not compsite? C'mon lets hear from some of the guys that have already quoted it as gospel in this thread. 1HP, 2HP, 3HP? Is th BBK intake loosing more power from being aluminum than its gaining from better flow? Does it even flow better? Where's the beef?
Old 12-01-2005, 01:15 AM
slayer6x6's Avatar
I would really like some dyno runs hot vs. cold and see how much this heat soak comes into play.
Can heat soak really be that bad considering almost every performance engine before the LS1 had an alumnium intake? The LS1 is the first performance GM engine that uses the composite manifold.
Old 12-01-2005, 01:19 AM
NemeSS's Avatar
being the former owner of a weiand aluma manifold ican say that, i was not as pleased as with an ls6,i would assume that the bbk is subject to hi heat soak like the weiand,my weiand would get hot to the touch maybe over 100*-150* which cant be good for power also i polished my weiand to a near chrome finish to combat heat.
NemeSS is offline
Old 12-01-2005, 08:59 AM
SUTTERERMAN85's Avatar
i think that you add like 25lbs with the alum intake over the couple pound ls6. the ls6 is about 100 bucks cheaper also
SUTTERERMAN85 is offline
Old 12-01-2005, 09:02 AM
technical's Avatar
I say get the BBK and be the first to give us results. But I want to see before and after comparisons.
technical is offline
Old 12-01-2005, 01:39 PM
Nearly_Gone's Avatar
i got the BBK SSI intake and it is SUPPOSE to flow 15 % better than the LS6 mainifold and it looks sexy. i havent diven my car yet since i put it on so i dont know for sure but thats what tech said at summit when i bought it. and it was cheaper than the LS6 manifold
Nearly_Gone is offline
Old 12-01-2005, 01:47 PM
Full-Force's Avatar
So far I have head " it was hot to touch and that cant be good for power" and that an aluminum intake is 25 pounds. Alumnim intake dont weigh but about 7 - 10 pounds tops.
Old 12-01-2005, 01:53 PM
oh noooooo
mine was heavy as ****.
Old 12-01-2005, 05:03 PM
slayer6x6's Avatar
Go drive that thing!
Old 12-01-2005, 05:35 PM
Redneck Z's Avatar
The BBK is more expensive, probably 25 lbs. heavier and will suffer from heatsoak. Heatsoak will be more of a problem for a street car, because you can't ice it down at every stoplight. I believe the BBK design is based off the LS6 and doesn't flow any better or worse. Obviously I voted for the LS6!
Redneck Z is offline
Old 12-01-2005, 05:42 PM
J&J Motorsports FL's Avatar
I sold my weiand to get a LS6. That aluminum intake was a heavy bitch. Have not run the LS6 intake yet though. But I think the LS6 and weiand flow the same. My vote is for the LS6
J&J Motorsports FL is offline
Quick Reply: BBK vs. LS6 (Intake Manifold)
