WTF is wrong with my damn raptor shift lite!!!!
SOB.....I got my raptor shift lite in today and hooked everything up, tested out perfect. I hop in the car to try it out.....nothing.
What happens is this....you turn the ignition on and the lite flashes letting you know it's ready, hooked up, whatever. After you turn the key off and on a few times, it will quit working, and you have to remove the ground, and reinstall it, and it will work again for a few more times
What is the deal, everytime I take it off, and then touch it right back by hand, it will work, but after a few times of off and on while it is secured....it loses ground, and it has to be "reset"....this is ridiculas.....any ideas???
Where did you ground it? and what is your power source? Are you sure you've got good connections on both?
I grounded mine to the frame of the car whereever it shows on installuniversity.com and used the power from my headunit. I can't think of why it'd be messing up the way your describing unless one of your connections isn't solid.
yo man why dont you try opening your door?
turn off the key and open the door then turn the key back on
i bet thats what it is
i freaked out over the same thing with my car
you hooked it up to a powersource that is on only when the key is on and after you turn the key off you know how your radio keeps playin and windows still work thats the problem...open the door haha
Originally Posted by Hocky
My damn raptor light goes through its initialization but will never light up at its specified RPM. I guess it is garbage. :-\
if i remember correctly, for an LS1 it should be set to 4cyl
Kevin
Ok, I got a for sure good ground, but thing is, after carefully looking at the instructions for the cylinder selection, and yes, I knew it was suppose to be on 4 cyl. Anyhow....I just looked at the pic of the 3 switches, which were just the opposite in color as the real thing....so I had it backwards....damnit, all this time. I happened to see where it said the switches were in BLACK, where as I was assuming the switch was the white area....like the actual color of the switch...I guess that's what I get for thinking.
Yeah, and the door thing....that seems to be right on as well, so I had a few things off.
So on to the good stuff...I LOVE it.....wish I had of gotten one sooner.....works great, super brite, and looks sweet.
Thanks for the help fellas.
