Underdrive pulley and charging
Old 01-22-2006, 04:36 PM
registered user
ScreaminRedZ's Avatar
Default Underdrive pulley and charging
I keep seeing people making decent gains (8-10 whp) with underdrive crank pulleys. I'd like to buy one but was wondering if I should also get the overdrive alternator pulley to keep my battery charged?
Thanks
Old 01-22-2006, 05:19 PM
Cstick's Avatar
I would leave the stock pulley on. I have the overdrive alt pulley and it acts fine with no electrical loads on it at idle. But I have to keep the rpm above 1000 to charge above 13V when the a/c is on, and head lights are on. Not a big deal, and it is not going to drain your battery while you sit at a stop light. If I did it over again I would go underdrive alt or just stock alt. I think the ASP web site says what RPM will charge like normal, with each set up.
Old 01-22-2006, 05:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Overdrive for a system only.
Old 01-22-2006, 05:50 PM
10 Second Fun Car
jlrz28's Avatar
I have a MTI underdrive pulley, havent had any problems with it.
Old 01-22-2006, 07:49 PM
BudH's Avatar
I'm running the ASP Underdrive crank and alternator pulleys (4 years) on my 6 speed with no problems. But, I don't sit for extended periods in traffic.
Old 01-22-2006, 08:02 PM
BackinBlack02SS's Avatar
The stock idle for an M6 car is 800rpm. The stock idle for an A4 car is 550rpm. They both have the same alternator. The majority of underdrive pulleys/dampers slow down the accessories by 25%. Do the math, you will be fine.
Old 01-22-2006, 08:52 PM
Red99TA's Avatar
I notice the headlights flicker when below 1200 rpms but that's the only issue I have w/ it (just the ASP UD crank pulley and stock alternator pulley).
Old 01-22-2006, 10:08 PM
Kyle C's Avatar
SLP U/D and stock alternator pulley with no problems.
Old 01-22-2006, 10:38 PM
Big Ty's Avatar
asp 25%, no alt pulley. everything is working fine.
Old 01-22-2006, 10:49 PM
Brandon35thSS's Avatar
i have the slp ud crank pulley and have no problems
Old 01-23-2006, 06:18 AM
registered user
Thanks alot guys! I wasn't going to get one but after I keep seeing people making making decent power gains with them I just can't pass it up.
Old 02-05-2006, 12:25 PM
Tiger2o69's Avatar
If anyone wants to buy an underdrive alt. pulley I have one for sale. thanks.
