A.i.r. ?
Old 01-23-2006, 03:44 PM
FL01SS's Avatar
Unhappy A.i.r. ?
So I was looking at the A.I.R. system the other day trying to locate all the pieces that I would need to remove, and I discovered that the previous owner has removed the box or solenoid or whatever is suppose to be behind the driver's side light and replaced it with a little breather filter. So now I'm curious how this is effecting my engine? Isn't it basicly an exhaust leak right now? Or is there a solenoid keeping it from being open all the time? My first guess would be not, because of the amount of crud on the breather. I now believe I know where the exhaust fumes I've been smelling are coming from! Any input?
Old 01-23-2006, 03:54 PM
Zymosis's Avatar
A check valve in the air system should only make it flow from the pump to the air system. Most cars have the check valve fail. I say if you can, remove the entire system. (When you get headers or what not)
Old 01-23-2006, 05:32 PM
FL01SS's Avatar
I've got full length headers already. Can you buy the block off plates for them, or do you have to fab them?
Old 01-23-2006, 07:24 PM
FL01SS's Avatar
I guess what I am wanting to know is if it's hurting anything running it the way it is until I can get around to taking to off?
Old 01-23-2006, 09:59 PM
Marc '99T/A's Avatar
You can buy block off plates, but I'm not sure which sponsors sell them. Just look around. Or, you could just make them yourself.
Explained here:
http://www.ls1camaro.net/sections.ph...ticle&artid=70
Old 01-23-2006, 10:01 PM
keliente's Avatar
It's normal.
When you get an air lid, you no longer have the 'nub' for that air hose, since it was on the stock air box. Thus, you get a small breather filter. No it is not an exhaust leak and no you will not smell any fumes because of it.
Old 01-23-2006, 11:26 PM
Zymosis's Avatar
www.speedinc.com sells the block off plates
Old 01-24-2006, 09:13 AM
FL01SS's Avatar
Originally Posted by keliente
It's normal.
Thanks. It already had the lid when I got it, so I didn't know where that hose was suppose to run.
