Y-pipe touching
Y-pipe touching
I have pacesetter headers and a TSP y-pipe. The y-pipe is hitting on the cross member. Has anyone just removed it, or am I the only one that can't get it to fit right? G
I threw my tunnel brace away. But anyways my final fix was to put poly motor mounts in. I tried repositioning the y pieces but it got hard to twist them after the second or so attempt. I tried ovaling the pipe some in the area with no luck. I found that I would loose to much ground clearance to stop the banging so that is why I went with the motor mounts.
That's what she said...
Poly motors mounts = the ****.
If its hitting the tunnel brace, take that bitch off and chunk it. If its hitting the tranny crossmember, you need to beat/bash the pipe and adjust the system some more. 90% of the time, the pipes just need to be tweaked a little bit more
Originally Posted by peterock98
How do you fix it?
A possible easy fix is maby a poly trans mount. It has a bit of vibration to it, but it either goes away or grows on you, at least i dont hear it anymore. Less simple fix would be poly motor mounts, even though it would take alot more to put them in.
My tunnel brace was banging too, so I used some longer bolts and 3/4" worth of washers for spacing. Still bangs!! So that causes Knock in the engine? Does the engine see that and back off HP?
Throw the tunnel brace in the trash to get the y pipe from hitting the floor board you can tack a used valve spring between the y and the floor board where it hits!
