Plugs behind intake part numbers?
Old 01-30-2006, 07:08 PM
ilovefirstgens's Avatar
Default Plugs behind intake part numbers?
Well it seems that when i removed my engine from my donor car i seemed to have persuaded it too hard... the two electrical connections at the back of the lifter valley (if thats what you would call it) are totally messed up so anyone have any part numbers for them, i can get a pic if nobody knows what im talking about since unless youve pulled your engine you would never see them.
Old 01-31-2006, 10:47 AM
thunderstruck's Avatar
is one sensor on the intake itself and the other in the block? if so that is your map sensor and oil pressure sender.
Old 02-09-2006, 11:10 PM
No they are both on the block, just aft of the valley cover and barely visable with the intake on (def not for you guys with f bodys) could it be the cam sensor??? if anyone has any ideas let me know.
Old 02-10-2006, 07:19 AM
the cam sensor is also back there. forgot about that one. that is all the sensors that are back there.
Old 02-10-2006, 07:30 PM
The i cant seem to track down the cam sensor part number, even in the huge directory on here......
