Has anyone used these mufflers in a dual setup?
http://store.summitracing.com/defaul...6&autoview=sku
If so What did you think?
Will this work, If so This will be my first dual setup, What all do I need from headers back. I dont want to dump them.
Originally Posted by 99Hawk262
Yes those will work. Check out my picture for running them out the back. You can also go over the axle.....but it costs more and is a little harder. I have plenty of clearance. Those mufflers are LOUD but they will sound really good.
You'll need pipe....I went mandrel bent to the mufflers and crush bent behind. You'll need a crossover pipe (H or X-pipe). This is not mandatory but helps scavenge exhaust and equalizes the pressure. An H-pipe generally sounds better and a X-pipe supposedly generates more power (although this has been disproved via a dyno graph from a Mustang GT that was floating around this site somewhere). You'll also need tips. I guess you are going to have this made at a reputable shop? If so, they should have everything you need with the exception of the crossover and tips (depending on what kind you want). Search for crossover pipe manufacturers. (Dr. Gas X, Flowmaster H, etc.) You'll also need to decide if you want 2.5" (good for at least 600 bhp) or 3" exhaust. Opinions vary, but 2.5" is more than sufficient for most people's needs.
I wonder what one of those larger single chamber single in/dual out would sound in place of the stock muffler. Would probably flow a lot better than the 80 series catback. Would just need one of the pipes bent weird kinda like in the gmmg setup.
