lm exhaust question.......
hey guys, i just bought loud mouth exhaust off a guy off this website this past weekend for my 02 Z28 and i was just wondering, for those of u with this exhaust, how many clamps are supposed to come with it cause all ive got is one clamp and some other metal piece? I want to mount this exhaust on my car this weeknd, does it just use all the existing hangers, ect...... thnxs guys!!!
Mine had 2 clamps and you reuse the stock band clamp from the y-pipe to the intermediate pipe, I used all the stock mounts on mine, just unbolted the hanger on the passenger side from the stock exhaust an dmount it on the LM. piece of cake.
ok, thnxs. right now the y-pipe is connected to the left pipe, but thier wasent a clamp on it, but the guy who i got it from tried to remove it but it was put together so tight that it wouldnt pop off. will this be a problem as i need too put the pipe over the axle?
if you are talking about the rear pipes then no it wont be a problem to install with the rear pipes connected, as long as the intermediate pipe is not connected to the over axle pipe yet.
well, as it turns out, the intermediate pipe that bends to go over the axle is connected too the rear right exhaust pipe, only one not conected is passenger side rear pipe!
you are gonna need to disconect the intermediate pipe from the rest of the system, as I don't THINK you will be able to get it over the axle otherwise. May be possible to do, but again I don't think so. good luck.
just take a sawzall and cut it close to the same place the LM is conected or you can cut it right as it goes over the axle on the back side before it turns into the muffler. Easy stuff, you will see exactly where I mean once you get under there to do it.
