How do you re-install.....
Old 02-12-2006, 07:33 PM
SacLSWon's Avatar
Default How do you re-install.....
How in the heck do you reinstall the harmarnic balancer? I went to chevy, high dollar "snap-on" installer. Didnt fit. Thanks.
Old 02-12-2006, 07:57 PM
DaddySS's Avatar
The best way is to get a threaded rod, washers and nut. Thread the rod in, then pull it on with washers and nut. If it's really tight - heating it in the oven helps.
Hope this helps.
Old 02-12-2006, 08:00 PM
That's what she said...
TheBlurLS1's Avatar
ls1howto.com
Check the camshaft installation section, theres a whole shabangabang about putting the pulley back on.
Old 02-12-2006, 08:37 PM
iamsickofitall's Avatar
threaded rod is my first suggestion, but if it's as rare to find as it is around here, Napa part number 2801-225 is a longer bolt that will catch 5 or 6 threads in the crank snout - you'll need a couple big washers too
