Does Holley's "LS1" intake flow as good or better then LS6 w/0 being ported???
Old 02-13-2006, 03:01 PM
MakoLS1's Avatar
Default Does Holley's "LS1" intake flow as good or better then LS6 w/0 being ported???
61-300-111 Holley Aluminum LS1 intake manifold
The description says "LS1" intake, thats why I am wondering.
Old 02-13-2006, 03:29 PM
98Z28MASS's Avatar
It is as LS6 style manifold, however I had the same question as you and the results were overwhelmingly in favor of the LS6. You can get the LS6 manifold with all the collant lines, plugs, and gaskets from slponline.com for $399+ shipping. It is by far the cheapest place to get it and you have your choice of egr or non-egr, the non-egr one being the one thats $399. I ordered mine from there and im just waiting for the spring to install it.
Old 02-13-2006, 03:37 PM
~JOSHUA's Avatar
I have the Weiand/Holley manifold for the bling. From the feel driving around, it actually has more low rpm torque compared to the LS6 I took off. The ports as they go into the heads are narrower, so the velocity is boosted. That helps throttle response and low speed power. I could port, but the car is just as stout.. if not better than before the swap.
I don't know the flow or dyno #'s but I'd say that comimg from a base LS1 manifold there will be a nice bump in felt performance.
Old 02-13-2006, 03:41 PM
bigken's Avatar
I have the polished holley on mine, and I now have an intake leak from it not sitting right, I am either going to get new gaskets and try changing them or get a ls6, plus when I had it dynod and tuned due to the heat sink I lost hp every pull. but it sure as hell looks nice
Old 02-13-2006, 04:19 PM
SS1875's Avatar
I had the LS6 and then went to the Holley for a brief time...lost HP on the Dyno and couldnt get the damn thing to seal!! I put the LS6 back on and had no issues.
Old 02-13-2006, 04:22 PM
~JOSHUA's Avatar
How much power did you lose? I've been told that it's eally only around 3-5hp on a 450 hp engine. Small stuff.
Old 02-13-2006, 10:40 PM
magius231's Avatar
yes but if you have gone so far as to make 450hp, it wouldn't make much sense to choke it with a poor manifold design thats more expensive then the good one...even if it does look good
Old 02-13-2006, 11:12 PM
Retired Street Racer
Matt D's Avatar
The LS6 makes more power than the Holley. Plus like everyone said, the composite desgin does not heat soak. Go with the LS6
Old 02-14-2006, 08:20 AM
~JOSHUA's Avatar
I'd definately go with the LS6 for all out power.
But if you want something custom, you shouldn't fear a metal intake. They've been around forever and they're proven. You can't beat a polished manifold in the visual drag race.
Old 02-14-2006, 09:50 AM
98Z28MASS's Avatar
Yea thats why I almost went with the holly intake as it looks amazing when you pop the hood, haha but my engine bay is so dirty right now that it would just bring more attention to the fact that i havent cleaned it in a LONG time.
Quick Reply: Does Holley's "LS1" intake flow as good or better then LS6 w/0 being ported???
