where is your electric cutout located?
I am considering an electric cutout but I want to place it where it won't interfere with ground clearance, and won't rub on the car's underbody.
Anyone have pics or can clearly explain where you have yours located?
Thanks.
Thanks.
Mine's under the rear seat, bring the electric cutout with you when you get it welded in for the correct orientation. Ground clearance shouldn't be an issue, unless your car is lowered.
Moderator
Gains are in proportion to how much of the total
exhaust restriction is downstream of the cutout,
and how much your intake/heads/cam/headers
are able to push down an open pipe. A stock car
sees a small improvement only at the top end.
The harder you breathe, the more not exhaling
through a straw helps.
Originally Posted by 99zman
where do most mount the cut out with a loudmouth, before the resonator or after?? any pics would be nice?? thanks
