98-99 TB cam on a 00-02 TB?
Old 02-16-2006, 10:25 AM
mean02Z28's Avatar
Default 98-99 TB cam on a 00-02 TB?
Just wondering if anyone switched from a 00-02 TB cam to a 99-98 TB cam on their TB when they had theirs ported or bought a new one? This interests me because when I get mine ported soon, I'd like the faster throttle action. Thanks for your input.
Chris
Old 02-17-2006, 11:10 AM
mean02Z28's Avatar
I'm sure all that is required is a throttle cable adjustment, but has anyone had experience with this? Thanks.
Chris
Old 02-17-2006, 11:37 AM
BIG_MIKE2005's Avatar
I'm gonna have to swap mine. I bought a ported 02' but was told that the reason for changing the cam in it was because 98-99 models have a smaller cam than the 00-02.
If I'm wrong someone with more knowledge chime in.
Old 02-17-2006, 11:42 AM
Bad30th's Avatar
Although either one will fit perffectly with the blade on it in the other's TB...
The "hammer" side of the TB cam is bigger on the 00-02 models. I tried to use one with my 99 TB and it pulled the cable too tight and it was keeping the throttle open slightly, couldn't adjust the cable enough.
The reverse is true using a 98-99 TB cam in a 00-02 TB, the cable will have too much slack.
YMMV if you mess with the cable adjustment enough.
Rob (Bad30th)
Old 02-17-2006, 02:22 PM
mean02Z28's Avatar
So is it possible to take the slack out through adjustment or not?
Old 02-17-2006, 02:28 PM
Bad30th's Avatar
I wasn't able to in my situation, but that doesn't mean it's not possible...
Since you need to take up slack for yours (as opposed to me needing to lengthen the cable) it may be possible.
Rob (Bad30th)
Old 02-17-2006, 05:30 PM
90nova's Avatar
I just swapped a ported 2001 on my 99. I had to order a longer cable to work. I still have my 99 throttle cable is anyone wants it, just pay for shipping.
