View Poll Results: what's your choice will be ?
True Duals
209
65.11%
ORY & Catback
112
34.89%
Voters: 321. You may not vote on this poll
poll: true duals VS Ypipe & cat-back?.....
Old 02-18-2006, 09:43 AM
Z28*POWER*'s Avatar
Default poll: true duals VS Ypipe & cat-back?.....
At the moment I have the ordinary set up:
Hooker lt’s , custom Y pipe (no cats) , borla with (Corsa tips) = sound like A$$
That’s enough!! I am going to change my whole exhaust by next month and still don't know what to go with , a lot of members here r going with duals these days .I want my car to sound like mustang ...they have nice rumble
So what do you prefer and why? Vote plz
thanx and regards
Bu Kahlifa
Z28*POWER* is offline
Old 02-18-2006, 09:54 AM
MM98's Avatar
Either 2.5" or 3' duals with x or h pipe & 1 chamber flowmasters.. There is no substitute, this set up sounds killer!
Mike
MM98 is offline
Old 02-18-2006, 10:01 AM
YellowMonster87's Avatar
Pacesetter lt's to 3" TD's out the back with dynomax bullets. I absolutely love this setup. It is crazy loud, and it makes me smile each and everytime i start the car. As far as wanting to sound like a mustang, my exhuast doesnt sound like a mustang, it sounds like a WS6 and thats how i like it. anyway my vote is definatly going to be TD's all the way!!! and you will see some performance gains over the ory setup you currently have.
jus my .02
seth
YellowMonster87 is offline
Old 02-18-2006, 10:40 AM
blue01ta's Avatar
True duals sound better IMO. And had you not already bought the ory and catback and had them dumped at the axle would've been cheaper.
blue01ta is offline
Old 02-18-2006, 03:25 PM
300bhp/ton's Avatar
thanx and regards
Bu Kahlifa
Honestly the best thing to do is read and learn about exhuast setups
Moany will say "oooo get duals they are best" but this is just a myth from people who don't really know. And there does seem to be this ethos that duals - make a car.
Rubbish. Duals can be good, but they may not always be better and for other reason can be worse.
In performance terms it's all about flow rate. A good 3" Y setup is fine for most owners and larger 3.5" setups work even better. A Y pipe scavenges in a similar mannor as an X pipe so you get the same advantages. It's purly pipe diamter that is a restricting factor above certain bhp levels.
Duals are great and ultimatley a 3" dual setup has the best flow, but most Fbody's make no where near enough power to utilise it.
Duals are also an issue as there are few off the shelf kits, and most that are available dump before the axel, so they are VERY loud.
Custom setups are great if done well, but a poorly design system will have fitment and clearance issues along with the possibility of lower performance. So research it well.
Duals also can be a hinderance if you want to run an after market torque arm as it will limit your choice or you need to design the system with the torque arm in mind.
As for sound, well that's personal. The LS1 will NOT sound like an OHC Mustang. But it can still sound good, just a different type of sound.
Duals do sound GREAT, but really Y pipes don't sound bad either.
Check out the GTO clips on this website, it has duals and IMO is the best sounding LSx setup I've heard: http://www.stainlessworks.net/cart/m...da6d13de0410e3
300bhp/ton is offline
Old 02-18-2006, 04:24 PM
blkZ28spt's Avatar
Search. The answer is obvious.
True duals with Sweet Thunder chambered mufflers is what you want. Period.
blkZ28spt is offline
Old 02-18-2006, 08:36 PM
1BDWS6's Avatar
My car with true 3" duals, X pipe and 1 Chamber Flows
1BDWS6 is offline
Old 02-18-2006, 08:56 PM
Louie83's Avatar
Good post and the GTO does sound bad ***!
I personally think a catback with cats sounds the best.
True duals make it sound like a race car, which is cool and red neck both at the same time. Sometimes they even remind me of a garabage truck, but hey...whatever floats your boat.
Edit: I fixed "read" neck. Note to self: "red neck" is a bad thing to mispell.
Louie83 is offline
Old 02-18-2006, 09:01 PM
1BDWS6's Avatar
Well...I guess I'm just a READ (RED) neck... cause I know how to spell and like the true duals sound.
1BDWS6 is offline
Old 02-18-2006, 11:01 PM
blkZ28spt's Avatar
Duals will make more power.
The difference is under the curve. Max power may be the same or very similer, but there will be a difference under the curve because proper duals with an X-pipe WILL scavenge better than a Y-pipe.
That said, you can go PLENTY fast with a proper Y-pipe.
That said, duals sound better.
Old 02-19-2006, 12:29 AM
4mula's Avatar
my pacesetters, orp and hooker exhaust sounds kick ***.
i used to have a magnaflow catback on the car, but it was too raspy sounding for me.
while under the curve power is always better than just peak power, the duals dont make that much more power.
4mula is offline
Old 02-19-2006, 12:31 AM
That's what she said...
TheBlurLS1's Avatar
Click the link in my sig that says TSP/Magnaflow duals
Pics/vids in that thread.
TheBlurLS1 is offline
Old 02-19-2006, 07:28 AM
z28convert's Avatar
Im with MM98 I have the h-pipe and it sounds great
z28convert is offline
Old 02-19-2006, 07:59 AM
TXZ28LS1's Avatar
i agree 1 chamber flowmasters sounds sick....im wondering why borla with longtubes sounds like a$$...borla is one of the better catbacks for the ls1!!
TXZ28LS1 is offline
Old 02-19-2006, 09:29 AM
Z28*POWER*'s Avatar
thanks guys for your help , after watching TheBlurLS1 sound clips in his sig i decided to order true duals from TSP with sweet thunder...that is the sound i was looking for in my ls1
i think mine will be louder than TheBlurLS1 because i have cam ,lt's ,no cats and ST muffler's
Old 02-19-2006, 09:46 PM
FstBlkz28's Avatar
If you aren't worried about ground clearance, and want to run an Off road setup ... I'd do a 3" Hpipe setup. Dumped at the axle or over the axle. You wont beat the sound of duals on these cars.
I went with a catted Ypipe and catback just b/c I got tired of the drone of the 3" X pipe and the clearance problems.
FstBlkz28 is offline
Old 02-19-2006, 11:41 PM
BrianC98Z28's Avatar
I personally think duals are overated. As many people that get them, you will see an equal amount who have gone back to y pipe setups because they get tired of drone and ground clearance. a good 3in o/r ypipe w. flowmaster merge and a good catback will make more than enough power.
BrianC98Z28 is offline
Old 02-19-2006, 11:52 PM
TheBlurLS1's Avatar
Here's a video of me running before i had the cats put in. It was straight duals w/ dumps, LT's, no cats, and a cam in this one
The video doesnt do the sound justice, it was awesome. It's alot quieter now, but i still think it sounds great.
BTW - this video is hot off the press
http://videos.streetfire.net/player....0-DD55CF5232B2
Old 02-20-2006, 03:53 AM
BlackHawk T/A's Avatar
Duals all the way, though i'd be worried about an under the axle setup like Blur's...not for clearance, but for the hassle of having to remove the rear pipes from the car every time it needs to be jacked up to be worked on.
BlackHawk T/A is offline
Old 02-20-2006, 10:28 AM
blkZ28spt's Avatar
I do not think there are anywhere near as many people who went back to a Y-pipe after trying duals as there are currently running duals. Perhaps a poll is in order, but I would be willing to bet that the VAST majority of dual owners keep them.
The lowest point on my duals is where the factory Y-pipe is crushed. If the duals are tucked up properly the ground clearance won't be any better with a Y-pipe.
If the drone is that bad the first thing to try is different mufflers, then taking them out the back.
Quick Reply: poll: true duals VS Ypipe & cat-back?.....
