Is it ok to yank out air system ?
Yes.
FYI: In the future the stickies and search button can answer all kinds of questions such as this.
If you get it tuned off properly you will have no SES light and no problems whatsoever.
Ditched mine and didn't get it tuned out yet. Still no probs at all. Only the ses light but it's not throwing a code for the air pump just the rear o2's.
BTW there is no performance gain from this just a cleaner looking engine bay. And cures backfiring if the check valve is bad.
Originally Posted by TheBlurLS1
The AIR system is a piece of ****. It works on this principle.....
"Dilution is the solution to polution...."
Originally Posted by FBodyPerformer
whats the use of this? just to free up space in the engine bay to make it easier to work in?
Extra work space, less to remove everytime you do work, weight reduction and less systems to have a problem with in the future.
I would say if you are not running cats, then yes definately get rid of it and get it tuned out. Gets rid of unnecessary clutter under the hood and makes it easier to work on stuff.
If you are running cats, I would leave it in. Anyone care to comment if you plan on leaving the cats in???
That's what she said...
Just make damn sure you don't take the car to have a sniffer test done when its dead cold! The cats have to reach a certain "operating temp" if you will, before they start catala-sizing the sheit.
Just like when a plant wants to dump 1000 gallons of **** in a river, and can only dump X amount PER gallon of water, they just put it more water! It's alot cheaper than paying the fine
Remove it even if you are running cats. This is how this system works: When they take a sniffer test to the car, it counts the amount of pollutants per exhaust gas that is flowing out. If you pump in a **** load of air while this is happening, it will appear that there is less pollutants per amount of air coming out, which is true. HOWEVER the same amount of overall "bad stuff" is coming out, AIR pump on or not.
I think the AIR pumps do reduce emissions - they only run for a few minutes when the engine (and cats) are cold. They pump fresh air into the exhaust upstream of the cats. The purpose is to get the cats up to operating temp quickly - any small amount of unburned fuel in the exhaust will burn up before / in the cats with the fresh air dumped into the exhaust. This will heat the cats up quicker - then the air pump turns off.
When the car is cold, it is in open loop and unless your tune is perfect there is a reasonably chance your air/fuel ratio is not perfect.
I think the AIR pumps are not there to dilute the exhuast gas - if thats all they did, your right there is still the same amount of "bad stuff" coming out.
You are correct......
