ORY Hitting Floorboard!
Old 02-19-2006, 12:58 AM
273sunsetZ's Avatar
Default ORY Hitting Floorboard!
What should I put in between the floor board and the ORY because it keeps banging the floor, it practly rests on the floorboard, and there is no more room for adj. I was thinking about some sort of rubber, but it might melt.. Any suggestions.
Old 02-19-2006, 01:00 AM
Lrry93's Avatar
Thunder racing makes a bumpstop just for this. for around $40
Old 02-19-2006, 01:05 AM
That's what she said...
TheBlurLS1's Avatar
An old valvespring.....
You could remove it and do a little pipe/floorboard bashing.
You would look somthing like this....
Old 02-19-2006, 12:04 PM
Azrael's Avatar
I used heater hose held on by a huge hose clamp.
Cut a length of the hose run the hose clamp through without closing it, wrap around the y-pipe just under the driver's side floor board and sandwich it between the floor board and exhaust pipe. Then slide the hose clamp together and screw it closed until tight enough not to move around. Viola' instant bump stop mod...
Or buy the Mufflex bump stop from a sponsor for about $45---->
Old 02-19-2006, 12:10 PM
WhiteRhino's Avatar
Another thing you could do i swap to poly motor mounts.It usually stops the banging as well.
Old 02-19-2006, 12:55 PM
99Hawk262's Avatar
I have this problem too. Poly mounts are sitting at home waiting to go in this week. I'll post after they are in with my thoughts.
Old 02-19-2006, 01:13 PM
HavATampa's Avatar
I wouldn't put anything between it because you will always have some vibration or weird noise at that spot. Flattening the pipe a little at that spot won't hurt a thing and that's the route I would take. Also, like the others said install poly mounts. But if the pipe is always resting against the floor, poly mounts won't fix it.
Old 02-19-2006, 02:17 PM
Azrael's Avatar
Actually I have not expereinced any more vibration per se, since all of it is transfered into the car one way or another. The hose actually does help to dampen though... *shrug*
I agree the all around best method though is Poly motor mounts!
Old 02-19-2006, 04:04 PM
slow trap's Avatar
hey justin,i figured it would bang pretty bad.take it over to aaa and have them to do alittle massaging.do you like the sound so far ?
Old 02-19-2006, 05:28 PM
4mula's Avatar
i disagree, just heat up the y pipe and bend it alittle.
i did that and problem solved.
Old 02-19-2006, 05:37 PM
273sunsetZ's Avatar
Ya, it sounds great, and loud with the LM. Thanks again for helping me install them yesterday, I never would have solved the minor problems we ran into without being at your machine shop. The bang is pretty loud though. I thought about mabie putting some garden hose inbetween it. I don't know. My moms gonna kill me though, I told her last night i fixed my clogged cat problems. I can't wait to pull up next weekend and see her face
Oh, where is aaa??
Old 02-19-2006, 05:39 PM
273sunsetZ's Avatar
Was your y-pipe in four pieces like the TSP one?
Old 02-19-2006, 06:04 PM
wicked z28's Avatar
You Dont Have To Put Anything Just Take IT To An Exhaust Shop And Have THEM Heat It Up And Bend Into Place,problem SOLVED
Old 02-19-2006, 07:17 PM
slow trap's Avatar
aaa is where you seen me at the other day. they will be able to heat it up and gain you some clearance.
Old 02-19-2006, 08:16 PM
273sunsetZ's Avatar
Alright, I'll probably just stop by there tuesday. I only have one class that day.
Old 02-20-2006, 10:54 AM
98redorangeta's Avatar
My buddy just weaged an old break pad in there and it fixed it i couldent belive that it worked but it did.
