Pacesetter Long Tube Install...Need Help.
You guys got any tips or advice on installing ym pacesetter long tubes on a 2002 Z28......anything to make it easier would be great.
I had to grind off a casting tab on the block to get the drivers side to go up and in. I reused the stock metal gasket and header bolts too. No leaks or loose bolts after 2k miles.
Originally Posted by yak
have you started? they just slide right in. I can do a set of pacesetters in about 3 hours.
Restricted User
I just did them on YellowMonster's car, Before you actually go and put the headers in, take out the driverside plugs and the steering rod. It took me about 2 hours to take off ALL of the old stuff off and put on the new headers doing that. It's very easy for ya and just be patient.
We took the coil packs off during my installation, takes about 10 minutes, afterwards It didn't seem as cluttery. Over all, it was a piece of cake, except for the T/S ypipe, which took longer than the header installation. Just make sure your car is off the ground as high as you can get it, and that should be your biggest problem..
Hey guys.....I didn't get the Y-Pipe, strictly because my buddy owns an exhaust shop, so we're fabbing a custom Y w/ cats........but it looks like the headers would be a bitch! So, just remove the coils, plugs, wires and move the motor over? Do I need to go in from the top or bottom?
Nice Car
Originally Posted by slow trap
the 4 piece y-pipe gave us more trouble than both headers,the headers slide right in.go ahead and lose the a.i.r and get you some block-off plates to seal the fittings.
Restricted User
Remove all the wires from both sides (emmission equiptment also) and the ds plugs and the steering arm. After that, you shouldnt have to take off ANYTHING if the car is high enough off the ground. The motor doesnt need to be moved either.
Mike
I did my pacesetters yesterday, they were the race style headers with the pacesetter y pipe. the only thing i need to know is how to get rid of the egr tubes that come off of the old headers
The headers go ion from the bottom. I took the coils off to keep from f**king my arms up getting bolts in place. It makes things a little easier to get to, but you don't have to remove them. Pull them out of the way if you want to. I removed the spark plugs after i removed the stock manifolds, but didn't remove the steering shaft. Most prople don't actually, they just take a file/sawzall/hacksaw to the piece of casting flash on the left side of the block near the bellhousing. Remove 1/8", then they slip right in. No need to move the motor or unbolt enging mounts unless you are replacing them (it is a good time to do that). Use search to find a picture of where to grind. Just use a simple metal blockoff that you can make or buy one that a sponsor sells -----> cheap either way.
What do you mean by this. not sure i understand. clarify and ill try to answer
