y pipe bangin curious ??
i have read about the y-pipe banging when you do headers, how annoying/bad is it is it really that bad?? anyone know of a makeshift way to fix this. i was thinkin of havin my exhaust man weld a bar from the pipe to the body but it may break? flex pipe at collector? mufflex hanger really work?
I just got some installed and the y does bang the floor. I'm going to go to an exhaust shop and get them to bend the pipe to fit the dip in the floorboard. Thats what everyone tells me to do. It worked for them.
Take a 4" angle grinder and cut out the part of the floorpan that's in your way. It took me a little while to get it right, but my pipe now has good clearance. My Kooks setup tucks way too well.
Originally Posted by black_z
Im going to weld a valvespring between the ypipe and floor, or crossmember. My pacesetter y banged horribly, a poly tranny mount and some radiator hose helped, but its not gone.
Originally Posted by 99blancoSS
How is a poly tranny mount supposed to stop the engine from rocking? The real problem here are the soft rubber factory motor mounts. Replace the drivers side and your done with it. I've been this route. Take it to an exaust shop and get underneath and look for the tights spots and adjust accordingly but you'll need to swap motor mounts to stop the banging. Anything else is just a bandaid and isnt solving the problem. Welding valve spring?!? wtf, Please fix it right.
