worth the swap?
worth the swap?
01 Z28, is it really worth the money to do the 90/90 LSX and Nick williams swap. and if so what kind of power gains might i have.............thanks
I wouldn't suggest a FAST 90 setup on stock cubes at all. An LS6 intake is about your best bang for the buck regadless of mods on stock displacement. Strokers, on the other hand, pretty much require it to show their potential.
Originally Posted by Out1aw
Use that money and get yourself a good throttle body and a cam.
Originally Posted by YouCantCmyZ28
whats the stock mm size of the tb, and would it be better to just port it or get a new one....thanks
Originally Posted by outkast6991
stock is 78mm.everything i've read and after talking to jason says 90/90 after big cam or h/c swap only.
its hit and miss with the 90/90 setups. if you have a big setup that really needs to breathe then ya, but an LS6 intake with a Shaner TB or any other ported TB is usually sufficient. Also if FAST would come off the damn prices and get their heads outta their asses it would be a hell of a lot better. For the price of the setup, you could get a set of heads.
Another + for porting your own TB and stick with the LS6 intake.
For the money you could do a nice cam setup and get much better gains, also get a stall it'll make more difference in SOTP and ET's than a 90/90 setup could ever hope to do.
