Last header related question, I promise
Thank you for all of your help so far. It is almost time to order my headers and Y pipe.
I am going to go with the Pacesetters ceramic coated headers because the QTPs are just too expensive for my college student budget, I want to have a little money left over after all is said and done.
I am thinking about going with the TSP ORY because all Y-Pipes flow the same right? And TSP has a good deal going with the pipe and headers. And from what I can tell all they do is plug in your car and see if you throw any codes here in AZ.
What other parts am I going to need to do the installation my self? I have heard about locking bolts and gaskets, but I want to make sure I have everything before I get the car off the ground and realize I am short something. Also how important is a tune after getting headers put on?
Thanks in advance for any opinions, suggestions, answers and/or advice you can give me. I want to get these things ordered soon so I can put them on over spring break.
~Alex
~Alex
I don't think the Pacesetter y-pipe will flow as well as the TSP. Personally, I have the Pacesetter Y and there are big dents in it so it will fit under the car with no banging.
So there Y isn not 3 inches throughout, and it still bangs the floorboard.
don't use the crappy paper gasket you can re use your stock gaskets and you will be better with those, the paper ones tend to have leaks,same with the bolts. Good luck with those new Headers
So just reuse the tock bolts and gaskets? Sounds too easy Also should I go with the EGR and O2 ones ore the race style?
~Alex
~Alex
i would get the ones with emissions fittings in case but it does add about 2 hours on to your install time. i just got done with mine took 11 hours alone, be aware of the passenger side manifold bolts im pretty sure there have been people cry over that last one. get all the bolts loose but the back one and pick your manifold up towards the coil packs and get that bolt from underneath it only took me 2 hours to get that bolt out.
I will have to see if I can get a little help, Maybe bump it down under the 11 hour mark. I am planing on getting a tune after I get the headers installed so would I still need to get the EGR and O2 compatable headers since I could just have them delete the code for them while I am getting the tune?
~Alex
~Alex
