AC and PS delete question
Old 03-09-2006, 12:09 AM
Arizona Mike's Avatar
Default AC and PS delete question
I'm thinking of using an LS1 in a '65 roadster replica that weights 2200-2300 lb and has manual steering (~45% weight on the front). I will be deleting both the AC and the PS leaving only WP and ALT. I'm assuming an underdrive pulley at this point would do more harm than good. What do you think?
Mike
Old 03-09-2006, 08:06 AM
Ωmega's Avatar
Nope! I run no PS, no AC, and an underdrive pulley on an automatic without any problems.
Old 02-17-2007, 02:13 PM
TonyG's Avatar
I cant find anything for an LS1 AC delete...who makes a pulley for AC delete for a 02 SS?
Old 02-17-2007, 02:39 PM
Z28_DAD's Avatar
dont need it since its run off a different belt
Old 02-17-2007, 02:42 PM
That's what she said...
TheBlurLS1's Avatar
Just pull the a/c belt and it's deleted.
You can remove the compressor, comressor bracket (and a/c belt tensioner), condenser (in front of radiator), the accumulator (some call it the dryer), and all the lines associated.
Old 02-17-2007, 02:45 PM
Z28_DAD's Avatar
and the evaporator. thats fun
Old 02-17-2007, 04:12 PM
bczee's Avatar
There was a post not to long ago asking the same question about just running the WP and Alt..
https://ls1tech.com/forums/showthrea...ght=alternator
Old 02-17-2007, 07:55 PM
sidewayz28's Avatar
i actually just deleted my AC about 10 minutes ago in my 01 camaro.. pretty easy
Old 02-18-2007, 02:51 AM
DanZ28's Avatar
Another option (this how I run mine) is to put on a electric water pump then you only need to run one short belt from the pulley to the alt. This makes it nice and clean not having the serpintine belt and no belt tensioner's and brackets either. BMR sells the alt bracket to do this mod, just an FYI.
Dan
