tq arm and x-pipe question
quick question:
Will this UMI Performance Tunnel Braced Mounted Torque Arm and
Texas Speed Rumbler X True Duals with sweet thunders have any interference or conflict? I am thinking about both but want to make sure they will work ok.
Thanks
John
Thanks
John
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by JB00SS
any recommendations if on a tq arm if i get the TSP x-pipe? I am still searching and reading...
Any torque arm should work as long as it mounts in the stock mounting location. The BMR crossmember and torque arms work well with our True Dual System. If ya'll have any more questions give me a pm.
-Zach
-Zach
Originally Posted by MikeSomething
So what you guys are sayin are to stay away from the tunnel brace mounted ones and stick w/ the torque arm mounted on the trans?
Zach: The BMR crossmember and torque arms work well with our True Dual System.
...pardon me for buttin' in, if I got it wrong. I was interested, because I like the X-pipe and haven't picked a TA. I'm looking for a tunnel-braced unit that would tie to 3-pt SFC's (rag top), instead of loading just the floor pan.
Hello,
Basically what everyone is trying to say is if you want to run a TSP True Dual system (X-Pipe) a tunnel brace mounted torque arm will NOT clear it. You then have have a few options....first is buy the torque arm and have a true dual exhaust system built around it..this is the best way to do it. This is what needs to be done if you really want and need a tunnel mounted set-up otherwise you have to go back to a y-pipe set-up. The other option is stick with a transmission mounted torque arm which isn't a bad thing at all. We recommend a tunnel mounted arm on vehicles running 10.50's and faster in the 1/4, even faster is ok in most cases but that is what we recommend.
If you take a look at the installation pictures in the link below it shows our transmission mounted torque arm installed with the TSP true dual system and clears excellent. This arm is very inexpensive at $289.99 as well.
http://www.umiperformance.com/2205.aspx
If I can help as well please ask. Thanks
Ryan
Ryan
how bout a recommendation for my car: garage queen, 3-4 times a year to the strip, she is a H/C car(well cam only now heads are on the work bench) with 3.73's.
do I go tranny mount or tunnel mount?
