LS2 thermostat on LS1...?
Old 03-09-2006, 07:24 PM
joecar's Avatar
Default LS2 thermostat on LS1...?
Will the LS2 thermostat and housing bolt up to the LS1 coolant pump on a LS1 engine...?
Old 03-09-2006, 08:12 PM
FUN LS1's Avatar
No, get the Katech 160* stat. I got mine from SLP.
Old 03-09-2006, 08:33 PM
WhiteRhino's Avatar
It depends on if you have the newer water pump or not.Do you have the origanal pump or a newer one.If you have the older style you cant use it.If you have a replacement pump,more than likely its the new style and you have to use the Gto one.
Here's a recent thread explaining it as well.
https://ls1tech.com/forums/showthrea...ght=thermostat
Old 03-09-2006, 10:53 PM
joecar's Avatar
WhiteRhino,
I have the old style LS1 pump and a Hypertec 180 TS.
Ah, I see, the new style LS2 pump, LS2 thermostat and LS2 TS housing, together will fit my LS1.
Thanks, I appreciate your help, I searched but didn't see that thread.
Regards
Joe
Quick Reply: LS2 thermostat on LS1...?
