FAST intake does not want to sit flush?
Old 03-11-2006, 12:00 PM
Moderator
davered00ss's Avatar
Default FAST intake does not want to sit flush?
Installing my FAST intake. The intake does not want to set flush on the heads. One side at a time will fit down on the heads? Replaced the vallye bolts. I am replacing an LS6 intake.
Old 03-11-2006, 12:17 PM
Moderator
Could it be the wires for the knock sensors?
Old 03-11-2006, 02:35 PM
Moderator
Front coolant line. I hat my car right now. But the intake will be done in about 15 min. Had to take a bathroom break.
Old 03-11-2006, 03:18 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Its always great to post up and solve your own thread.
Old 03-11-2006, 04:13 PM
Moderator
Helps if someone else has the problem.
Old 03-11-2006, 06:00 PM
Moderator
it's done.
Old 03-11-2006, 09:08 PM
rufretic's Avatar
Looks good! Cant wait to get one myself.
Old 03-12-2006, 07:28 AM
Moderator
This deal was too good to pass up. Got it from a friend for the same price I sold my ls6 intake for. So you could say it was free.
Old 03-12-2006, 11:18 AM
mike c.'s Avatar
is that a 78mm or 90mm intake? if it's a 90mm how did you get the ribed boot to fit over the th-body?
Old 03-12-2006, 11:20 AM
Moderator
That is the 78mm, but we did a 90mm on my friends car.
The SLP smooth bellows fit fine. It has the Nick Williams TB.
Old 03-12-2006, 12:26 PM
ShevrolayZ28's Avatar
Nice Dave! What's next, heads?
Old 03-12-2006, 05:36 PM
Moderator
I want AFR 205's, but the wallet says otherwise.
Old 03-12-2006, 06:17 PM
lol they are pricey!
If you were to do it again, would you stick with the TR224 cam? At this point, I'm planing to use that same H/C combo.
Old 03-12-2006, 06:19 PM
iamsickofitall's Avatar
i was able to get the stock bellow to fit about 1/2" inch onto the throttle body after heating it this weekend - it is ghetto-ly held on there by tape until my smooth bellow gets delivered on monday
Old 03-12-2006, 06:23 PM
Moderator
The TR224 is a great cam. i would get the same cam if I had it to do over. Easy enough if I decide to change later. As for Heads, I have several on the mind. AFR's, PP 243 castings, PRC (texas speed) 243's or 5.3's. I want the AFR's but the price is up there.
