SES after installing Pacesetter LT headers
Old 03-15-2006, 05:23 PM
99LSGUN's Avatar
Default service engine soon?!!!
hey guys whats up?
i recently just got my paceseter LT's, SLP Loudmouth and ORY pipe put in and everything was cool and today i was coing home from work and all of a sudden my " Service Engine Soon" light came on. after i was done flipping out i couldnt understand why it came on if you have any clue let me know thanks.
Old 03-15-2006, 05:25 PM
Starz T/A 17's Avatar
Take it to either advanced auto or autozone and get them to read the code for you they will do it for free. Did you hook the emmisions crap back on and put sims in the back?
J E T's Avatar
Originally Posted by 99LSGUN
hey guys whats up?
You need to either purchase o2 sims (about $90) or have a tuner delete your rear o2's.
Old 03-15-2006, 06:42 PM
99LSGUN's Avatar
the shop put o2 sims in the rear. and i drove it again later today and the light was on then went off i dont understand at all let me know if you have heard off this or anything would help thanks for the previous info.
Old 03-15-2006, 06:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Its the front o2's acting up most likely. Get it scanned at autozone to be sure. Mine came on and off as well...get some bosch 13111's if it keeps bugging you.
Old 03-15-2006, 07:11 PM
yeah probally a P1153 Im having that problem after I put my headers on
Old 03-15-2006, 07:41 PM
01RedT/A's Avatar
if you need a set of working o2 sims, pm me. ive got a good set i can sell you.
Old 03-15-2006, 10:19 PM
99LSGUN's Avatar
is it a big deal? like will the light effect my performance? witht he sims acting up? or should i not worry about it till inspection time?
Old 03-15-2006, 10:53 PM
2K2WS6TA's Avatar
The rear o2s are just for emissions they shouldn't affect the performance, but with the light going on and off, I'd be betting it's the front o2s (and they can affect performance) like Lithium said, get some bosch 13111s if the light keeps appearing.
One question for you, was today colder than it has been since you put the exhaust on?
Old 03-16-2006, 07:36 AM
777's Avatar
Could be that the 02 sensor's aren't heating up quick enough. I had that problem, so do a few others that have long tubes. I'd be willing to bet that that's the problem, especially since it is intermittent.
Old 03-16-2006, 08:48 AM
99LSGUN's Avatar
yea when i put the headers on the weather was like 55-60 degrees and yesterday it dropped to like 30 degrees so yesterday was the first cold day since the headers were on. let me know what this means or what it could be thanks.
Old 03-16-2006, 09:07 AM
777's Avatar
All it does is that if the 02 sensors don't heat up within a certain amount of time it throws a code. It just means you have to wait a little longer before the 02 sensors start to read correctly. Doesn't hurt anything, unless you are one of those people that crank the car up and go wot out of the driveway. They should be heated by 1.5 minutes or so.
Old 03-16-2006, 09:30 AM
99LSGUN's Avatar
ok cool but will the code come back on again like when it starts getting nice out like 50- 60 again and when it comes summer time like 90's will the light still come back on?
Old 03-16-2006, 10:23 AM
777's Avatar
It's possible, if that's the problem, but I'm not positive. Disconect your battery for like 5 minutes and see what happens. Typically, if codes come on and off they aren't a problem and usually are due to the 02 sensors.
Old 03-16-2006, 04:28 PM
2K2WS6TA's Avatar
Just a theory, it seems when you have headers, if the weather turns cold, the o2s start acting up more, the headers retain less heat then the cast iron manifolds, and it causes the o2s to get too cool to function correctly, but as the weather warms up the o2s problems seem to become less frequent
Old 03-16-2006, 08:59 PM
'Trust''s Avatar
I'm with 777 on this one, if he is right it happens because your o2's arent up in the engine bay anymore so they arent getting the heat from the motor to aid in warming up. If thats the case after a few resets of the PCM the computer will log the code in history and the SES light wont come back on for that code. Get it scanned to be sure though.
Old 03-17-2006, 07:38 AM
99LSGUN's Avatar
i got it scanned last night and the code if i remember right was p1704 i def. know those numbers were in the code. and how do you reset the PCM?
