View Poll Results: poly mounts how are they
No they didnt vibrate more than stock couldnt tell the diffrence.
34
91.89%
vibrated the shit out of my car and is very annoying
3
8.11%
Voters: 37. You may not vote on this poll
poly motor mounts your opinion?
ok i have the usual Y pipe bang and im thinking of goin with poly motor mounts or the prothane(are they the same thing) but im nervous because in my old mazda turbo i did them and afterwards i could make a coin dance on the dashboard how stiff it made it. is that the case with these mounts how much more than stock do u feel it with poly/prothane mounts and is there a diffrence in prothane and poly or is that just a name for them? it is my daily and i like a smooth ride and nice exhaust i also plan on doin a 224 112 or 114 lsa cam and i dont wanna shake the car like crazy
Neither of your choices. Yes the car vibrates more with my cam, yes it will stop the Y from banging, no I do not notice the vibrating now like I did when they were first installed, and yes the work is worth it.
What I've noticed with my poly mounts is that the whole car shakes more but there is less vibration's. The shifter barely moves (did move quite a bit). It's a very good mod, but I wouldn't do it with the headers on and the motor in the car. I may try if the headers were off and the motor was in the car but I don't know.
my buddy did his and said he just did one side at a time and jacked the motor up a little and slid the old one out and the new one in and that was it everything still in
I just went with the prothane mounts... I can feel the cam EVERYWHERE in the car. Shakes the back glass and all, cam is pretty large though. I also installed them before the motor went in the car, not sure how hard in the car???
That's what she said...
I recommend poly mounts to everyone. The only complaint I have is they raise the engine maby 1/4-3/8", but it's no big deal.
If you do feel a vibration, you will forget about it/get used to it in about 100 miles. My poly tranny mount vibrated pretty bad at first, then it either went away (doubt it), or I stopped noticing.
I had cam and heads with stock motor mounts, enging shook like crazy. I then had a 383stroker motor built with a bigger cam and went with Prothane mounts....engine sits perfectly still. As for vibration, it's like using a poly trans mount...makes you get more in tune with the feel of the car IMO.
