Difference between 98-99 and 00-02 F-boy radiator
Difference between 98-99 and 00-02 F-body radiator
Does anyone know what the difference is between the 98-99 and the 00-02 f-body radiators? Can one be modified to work with the other. Anyone also know where to get a cheap replacement radiator?
Thanks
Thanks
John,
The only differences I've seen are the sensor location mentioned aboved. If your putting a newer radiator in your pig, I'd suggest looking at a LT1 radiator.
It provides a little more coolant/cooling capacity and is basically a bolt in.
Here's a couple threads:
https://ls1tech.com/forums/generation-iii-external-engine/436630-slp-radiator.html
https://ls1tech.com/forums/generation-iii-external-engine/462131-radiator-upgrade.html
