Homemade Camaro Ram Air Pics...
RESULTS: Homemade Camaro Ram Air Pics...
Here is my version of the Camaro Ram Air through the grill mod. Going to Silver Dollar Fri night to see what gains it gives me. Previous best is 12.77 at 110 at Commerce.
looks good, im hoping to do something along the lines of madmans big gulp sometime.
what is the material that is on the top there?
how did you attatch the two hoses to the front?
I used a cutting board believe it or not. It is a cheap poly one at walmart. Cut the holes and pressed fit the 45 degree bends into it. I attached the front hoses with a 6" to 4" reducer. Plugged the 4" hose into the 4" part. The 6" part fit around the bumper holes where the gills are in the grill. Then I had to trim out a lot of foam to get the whole assembly to fit like stock but it has pressure against it from the bumper so there was no need to tape/glue/screw it into place.
i like it all exacept the two tubes you can see in the front...
i mean i understand that thats where they must be...but id at least paint em black, or set t hem back a bit..
but nice man..looks sweet!
Originally Posted by conan
Looks good. Did you put 2 coned air filters on the bottom of the hoses?
Thanks man...which tubes are you referring to? The white inside the air box? If so I didn't bother painting that part cause it will be covered by the air filter. Everything on the outside is black.
Originally Posted by dug
Does the car feel faster?
I am seriously impressed with BOTH set-ups. The timing is perfect for me- I just put a "Wings West" grill on my SS, with the big holes in it. It's perfect for this type set-up, and I was concerned about cutting through the styrofoam (thickness, etc.). Was it easy to drill/cut through? You guys made the rest look easy! I'm pretty sure there will be a noticeable gain, especially at speed.
So can I keep the A/C and not have to cut up anything, or are there other "adjustments" that it needs?
It looks like at highway speeds it will be really helpful and with a grill covering the holes in the front it would look great. Nice job, let us know how it helps out in the 1/4
