Oil pressure guage pegged
I was replacing my ls1 manifold with an ls6, must of broke my oil pressure sensor because the guage reads all the way to the right (80+ I think). We bought a new sensor and when we went to put it in, the old sensor didn't appear to be broken. We replaced it anyway and the needle is still pegged all the way to the right? If I did break the sensor wouldn't it read 0? The only thing I can think of is that it is grounded somewhere. Anyone else have this problem? Any help would be great. Thanks
Hmmmm, actually, if you haven't already pulled the manifold, you might not need to. Instead just disconnect the guage, check the connections from passenger side, re-install and re-check. If there are still traces of a problem, remove guage, replace with alternate one (if there is one), and re-check. This will tell you what it is exactly the guage or the wiring.
I'd be willing to bet its in your wiring. I had the same **** happen to me its such a pain to pull the intake off so i was trying to avoid it but i eventually said screw it and i took it off again. Turns out the wire for the connector broke off inside the connector so i went to the dealer and bought another one for 20 bucks and that fixed the problem.
