guys with tsp true duals please come in
hey guys im really looking into the tsp dual system but i saw they have a choice of mufflers.i was wondering which is the best all around one?and which is the best for a daily driver?also the fact its dumped in front the diff and its still under the body does it make the cabin or body vibrate like if ur running open headers?
I have that setup with the Sweet Thunders and they are awesome!Turned out at a 45' angle the only bad noise is at 1700 rpms.Can't wait to hear it with a big cam.Try to get some sound clips.
how much ground clearence do you guys have? i have a lowered t/a and was thinking about getting this exhuast. i have a 3" y pipe and with this i have good clearence? just wondering your opions
I run the TSP duals with sweet thunders and a TSP 242/248 cam, sounds AWESOME, like a funny car with mufflers on.....and I drive mine everyday too...love the looks that mustang owners give when I pull up... they stare straight ahead like they know they don't wanna **** with me...
Had the dynomax bullets and they sounded great too but rattled everything, the bullets flow slightly better, but the thunders sound great, not really a hp loss to be concerned about (maybe 2 hp because of more restricted flow if that at all? Some say no hp loss at all....) by going with the thunders at all unless your a dyno queen looking for top hp numbers to brag about....
Love the setup and have no problems with clearance or anything at all. Strongly recommend TSP TD's with either bullets or sweet thunders....better than just about anything else out there imo.
Here's a video clip with the bullets before I switched to sweet thunders...
http://video.ls1tech.com/category/Ca...2A92AC84E6.htm
I'm running sweet thunder's and they are alsome. mine isn't tsp though mine was done custom to what I wanted. I also ran mine out the side in front of the rear tire's. I don't like dumps under the body personaly.
im gettin TSP with bullets and im very excited
listen to this http://www.ls1sounds.com/true_duals/...S6-driveby.MPG
The bullets will rattle everything you thought was tight in your car...the sweet thunders don't rattle hardly anything at all...and I run a large cam with poly mounts...stringly recommend the poly mounts to reduce any rattling or vibrations.
I see you are in miami, do you go to towers car meet at all in davie? If you do I'll PM you when I head out there, you can listen to my car and get a good feel for what you want and see how it will work for you being lowered.
I see there are mixed emotions between the two mufflers (Sweet Thunders and Dynomax Bullets). Would anyone care to explain why you like one over the other? I'm not looking for a biased answer. However, if you own one setup and like it better than the other, say why. I too am considering TSP's true dual system, I am just caught between these two mufflers.
I also noticed that no one has mentioned the other muffler being offered with this system (Moroso Spiral Flows). I have never heard these before, and I am assuming there is a legitiment reason behind this?
What differences can you (or anyone else for that matter) make between the Bullets and Sweet Thunders in sound (not in performance, because there is minimal difference in flow...not even worth mentioning)? Can you compare the sound they "make" to something and describe it in words even? I have listened to just about every sound clip in the true-duals section that have these two mufflers on LS1Sounds.com. It is very hard to make a decision from these sound clips alone since every person has a different method of recording the sounds (with the addition of the differences of recording equipment to alter sound from one clip to the next)
They sound more tuned with a nice mild raspiness. ...less drone and more snap.
I still think they're kind of expensive for a bullet though.
sweet thunders sound great! my passenger side trunk speaker grill rattles at a 1500 rpm range and thats about it. i get compliments all the time. complaints as well but thats good to me. sounds like a muscle car. my boy has some on his lowered formula and he can roll a soda can underneath. the sweet thunders give lee way to mount up higher or lower. here's a pic of mine...
