ls6 install
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
ls6 install
ok i bought a ls6 intake today just the manifold, what all other parts do i need can i order the texas-speed.. Coolant Pipes & Plugs For LS6/LSX Intake Coolant Pipes & Plugs For LS6/LSX Intake....i copied and pasted that from there site will that be everything i need for the install or is there more that i need, and if so can you shoot me in the right direction to get the parts...thanks
the coolant pipe and the 2 rear block offs should be it. suggestion, take the vac line off of the brake booster, and follow it to the back of the manifold, there is your oil pressure sender, dont break it, you have to lift the hose up over it. also get four pieces of fuel line, and cut them in one inch sections, then cut them open so when you lossen the 4 rear most bolts, slide the fuel line pieces over the bolts to hold them up, as they can not be fully removed due to the cowl, less fumbleing. good luck.
